Exclude files from download via filemask
AlLeX_
I am getting all files from a SFTP server with a script but I have to exclude a certain file type from download. For example *temp files.
Thanks a lot for your help
AlLeX_
Thank you very much for your answer.
Is there a possibility to exclude a file via its suffix with -filemask switch? This is not mentioned in the documentation.
For example: I have to download all files except those with *.tmp sufix.
Something like this? (this does not work):
-delete -filemask <> *.tmp
That's correct, just that you can omit the leading *.* actually and use just |*.tmp.
You have also omitted the "equal sign", but I assume you actually use it, otherwise it cannot work.
The correct and simplest syntax is:
-filemask=|*.tmp
Excluded files
I need your help with what is happening to me.
I have a script that transfers files to an FTP server, I have no exclude or advanced settings, but the following happens to me.
I have 10 files with TXT format, 5 start with the name AB and the others start with the name CD, and it only transfers the ones with the name AB, the CD files are excluded for no reason.
Can anyone help me by telling me what is going on.
An additional fact, if I replace the initial of the name CD to DE, the same file is transferred without problems.
Attached is the command you are running..;
@echo off
  /log="C:\ep_depot\Temp\WinSCP.log" /ini=nul ^
  /command ^
    "open sftp://xxxxxxx/ -hostkey=""ssh-dss xxxxxx="" -privatekey=""H:\keys\SSH_private_key.ppk""" ^
    "lcd ""H:\Forms\Forms\Final""" ^
    "cd /DO" ^
    "put *" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Re: Excluded files
@Guest: Please attach a full session log file showing the problem (using the latest version of WinSCP).
