Speed difference
sunrisecc
Toronto, Ontario
Speed difference
I uploaded 3773 files to my server using the latest WinSCP via FTP explicit over TLS. It took over 45 minutes. I did see under the Progress column the status of 'connecting' very often.
I then tried the same files using the same method via Filezilla and it took 15 minutes.
What options can I change in WinSCP?
I am running Win 7 - 32 bit.
_________________
Seymour
sunrisecc
A further update.
If I delete the files uploaded via WinSCP, the connection drops every so often. However with Filezilla, it never drops.
_________________
Seymour
sunrisecc
Toronto, Ontario
I am attaching three logs, Filezilla and two foe WinSCP. The first is the default log for the upload and delete of the same files. The second is under the option of debug 1.
_________________
Seymour
  • winscp.zip (760.02 KB, Private file)
Description: see above
Thanks for the logs. Though the FileZilla log shows only the upload, not the delete.
sunrisecc
That is correct. I should have been clearer. Only the first WinSCP log has the delete in it. Shortly I will generate a log for the Filezilla delete.
_________________
Seymour
sunrisecc
Toronto, Ontario
New Filezilla upload and delete log.
_________________
Seymour
  • filezilla1022.zip (184.77 KB, Private file)
Re: Speed difference
Actually I do not see any disconnects in the WinSCP log.
WinSCP is indeed slower as it uses only one connection for the upload. As you are uploading several folders, you can save some time by checking Transfer each file individually :
https://winscp.net/eng/docs/ui_copy
Further improvement to this is pending:
https://winscp.net/tracker/875
For the delete part, WinSCP is actually faster then FileZilla.
