Portable still save in reg
deep-silver
Using WinSCP 5.5.5 portable still save some information in system reg.
Setting PuTTY application in Preferences -> Integration -> Applications -> External applications -> PuTTY/Terminal Client PATH
This will result in season information saved in system registry (under HKEY_CURRENT_USER\Software\SimonTatham) instead in temporary
Re: Portable still save in reg
What "temporary"? How does WinSCP portability relate to exporting settings to the PuTTY? Are you using some portable clone of PuTTY?
deep-silver
No.
Just have the setting checked under, remember pass season to PuTTY.
This create HKEY_CURRENT_USER\Software\SimonTatham
I use portable version of PuTTY which read/write setting from file.
deep-silver
What portable version of PuTTY are you using?
http://jakub.kotrla.net/putty/
[/img]
wincsp is automatically using registry setting when I set this under
  • 2014-10-21_154959.png (7.88 KB, Private file)
WinSCP explicitly supports only original PuTTY and KiTTY.
Though on http://jakub.kotrla.net/putty/ they state that their clone of PuTTY can still read settings from registry. So I do not see what the issue is. Is it about deleting the exported settings after you leave the machine?
deep-silver
YES!
Since we are using a portable version, these setting should not kept in registry rather in a file ready to carry anywhere
You haven't really explained it. The settings is just a temporary copy of WinSCP settings. You do not need to carry it anywhere.
