Copy Exist Directory
Kac
Hi!
Please help me.
My problem is: I need use Powershell and winscp, and copy directory and files in this directory. Ok. I can do it.
But if i copy 1 time to destination folder, all files updating. It is not good.
Example:
I copy
Server1\home\user\ (in this folder has many folders (folders name 08102014;09102014;10102014)
Server2 D:\CO\08102014;09102014;10102014\
How i can check exist folder on destination server or not exist? If exist do not getfile(copy) if not exist then run getfiles.
I know
if ($session.FileExists($remotePath))
but what need next?) I dont now. Sorry i have bad English.
Re: Copy Exist Directory
I'm not sure if I understand your problem, maybe you want to use synchronization, see Session.SynchronizeDirectories:
https://winscp.net/eng/docs/library_session_synchronizedirectories
Hello! Thank you.
If i use synchronization method then : I have 2 directories (source and Destination) I have ten(10) .txt files in source folder. When i run Synchronize this ten(10) files copy to destination folder. I need change some one files in destinations folder. And if i run script again (method Synchronize) my files in destinations changes??? I do not need if my files Synchronize when i run script again.
It is real?
NEW NEW NEW!!!!
Sorry!!
I have many directories MY REAL EXEMPLE:
In folder CHINA (Every day automate created folders 09102014; 10102014; 11102014; 12102014; 13102014 folder name = date)
I need copy (SFTP) this folder and include files to folder RUSSIA (09102014; 10102014; 11102014; 12102014; 13102014 folder name = date)
THIS FOLDER (09102014; 10102014; 11102014; 12102014; 13102014) has some .txt files.
Somebody files in destination folder I deleted (it is need for work)
If i run my script again. Files when i delete in sorce folder appear again. I do not need this.
It is real doing?
Thank you very much!
Спасибо.
Спасибо@
KAC
Hello!
How i can use WINSCP and Powershell to this work:
Folder 1 has many folders (they names 10102014, 11102014, 12102014, 13102014 .....)
I need this folder to destination folder (folder 2)
But i need condition IF someone folder exist she do not copy to destination folder and if folder dos not exist she (folder) copy to destination ((
