Disconnected from server
froggy
Ajaccio
First of all thanks a lot for this very nice tool.
The scripting ability is exactly what i was looking for.
I can forget about filezilla now.
I have a issue when uploading files, i get following error after first transfer :
"Disconnected from server"
i tried batch mode and gui , i have the same error.
the same transfer works fine with filezilla.
command line :
WinSCP.com /script=script.txt /log=winscp.log
script :
option batch abort
open ftp://login:pass@ftp3.akka.eu/
lcd J:\download\DEX
cd /IT/DEX/
put AF-CCA_NEO-*.tar.Z
close
i have also attached the script log file
Using WinSCP 5.5.5 on Windows 7x64.
OK, your server seems to fail on MFMT command that WinSCP uses to update uploaded file time to that of original file. FileZilla does not update file time by default.
Try to turn off Preserve timestamp transfer option:
https://winscp.net/eng/docs/ui_transfer_custom
You can also try to enable Transfer > Preserve timestamps of uploaded files in FileZilla, if it makes FileZilla fail the same way as WinSCP.
froggy wrote:
when i use the option "preserve timestamp" in filezilla, i have the same error message than in WinSCP
Thanks for the feeedback.
