Need to change file permission after SFTP
Jagadish.vr
India
hi There,
Unable to change file permission.
Re: Need to change file permission after SFTP
What is the problem? Any error message? Or you do not know how?
Thanks for your response. The problem is after I SFTP the file to remote server the file permission is set to 600.
I want to ensure the file transfered to remote server directory is set to "644" after completion of SFTP or set the permissions of all files in remote server directory to "644" [Enable GroupRead] in the same script.
Thanks much
Jagadish V.R
HI Martin,
I tried the below , however getting error - Cannot change read-only permmissions.
$directory = $session.ListDirectory("/abc/def/zxyz")
foreach ($fileInfo in $directory.Files)
Write-Host ("{0} with size {1}, permissions {2} and last modification at {3}" -f
$fileInfo.Name, $fileInfo.Length, $fileInfo.FilePermissions, $fileInfo.LastWriteTime)
$fileInfo.FilePermissions.Numeric = 644
Please attach a session log file showing upload of the file with the TransdferOptions configured to set the permissions. I.e. your original code that you have just removed.
Hi Martin,
I have attached 2 file below. Script and Log file. Issue faced is in the statement mentioned below.
Thanks much for all your support.
$directory = $session.ListDirectory("/roam/SLS/PDPA")
$filePermissions = New-Object WinSCP.TransferOptions
foreach ($filePermissions in $directory.Files)
Write-Host (" {0} permissions {1} " -f $filePermissions.Name, filePermissions.FilePermissions)
## Below statement not working ##
$filePermissions.FilePermissions.Octal = 644
Cheers
Jagadish V>R
  • WinSCP.log (10.66 KB, Private file)
Description: LOg File
  • Script.txt (2.1 KB, Private file)
Again, Please attach a session log file showing upload of the file with the TransferOptions configured to set the permissions. I.e. your original code that you have removed from your very first post. That's the only way that works.
You cannot set $filePermissions.FilePermissions.Octal = 644. This won't work. It's read-only by purpose.
