Cannot rename files/folders error 301 Moved Permanently
PaulaG
I am using winDrag&drop shell extension use is enabled, but the extension is not installed.
Install the extension or switch to compatible drag&drop mode (from Preferences window), which uses temporary folder for downloads.
I fixed it in Preferences so I don't get this particular message when I try to drag&drop, but then get the message below... Also installed extension.
"WebDAV resource moved to 'https://........."
301 Moved Permanently" - caused by trying to rename folder on drive
Re: Cannot rename files/folders error 301 Moved Permanently
PaulaG
Log file supplied for 301 moved permanently errors
Thank you. I am attaching log file here.
Let me know what suggestions or comments you have.
much appreciated.
Paula
  • 301error..log.log (323.3 KB, Private file)
PaulaG
Fixed bug log file attached - New bug report added
Yes, that fixed that bug (Log will be included) – I can now successfully rename files and folders.
Will this new zipped copy work for other users here if I give them the new WinSCP copy?
I do have a new problem though I just noticed, as such:
Once I have connected, if I try to Drag and Drop a file from the Winscp webdav interface to my desktop, the file disappears from the webdav share.
If I select the same file and download using the 'Download' toolbar button, the behavior is as expected; meaning it copies the file to my desktop as well as leaving it in place on the connected webdav share. I checked the Tools > Preferences > Drag and Drop menu and I think I have it right: Checked "Allow moving from remote directory to other applications" and selected "Use Shell extension".
This new problem is also in same log as I will submit to forum in my reply.
Thank you for your help.
  • newlog.log (163.75 KB, Private file)
Re: Fixed bug log file attached - New bug report added
Did you read this?
Since 5.14, it is always possible to use drag&drop to move remote files to external applications, while copy is always the default operation.
