Unable to use key file "C:/putty/calrsa.ppk" (unable to open
calswart
I have a putty ppk file that works in the graphical version of WinSCP but when I try to use it in a script I get the error Unable to use key file "C:/putty/calrsa.ppk" (unable to open file)
Why would the scripting version not be able to use the same file that the graphical version is using?
winscp version is 5.5.5
Re: Unable to use key file "C:/putty/calrsa.ppk" (unable to open
I'd guess that it's because the forward slashes in the path. You need to use backslashes in Windows path.
jdiaz
Phoenix, AZ
ppk file issues
I'm having a similar problem. The C# application is trying to access the ppk file using the ftp login as the network credentials. How do I keep this from happening?
Reply with quote E-mail
Re: ppk file issues
I do not understand, what you mean by that.
