Show iOS application names instead ID
evildog1
Hello
Can you make WinSCP to show folder name as iOS Application names?? it's very annoying when it shows as ID and i don't know witch application i want to see.
Re: Show iOS application names instead ID
Will consider this. Though note that WinSCP is generic SFTP/SCP client, not iOS device management tool.
Skeeve
evildog1 wrote:
I know but i most use Winscp for Jailbroken IOS device
Did you consider using iBrowse from Macroplant for this purpose?
It's free and should show you the correct names.
