Transfer more than 1 file type to different folders
jeffwest2
England
Trying to move two separate files to two folders which are supposed to be the latest ones
In one file I have the following
winscp.com /Command "Option batch abort" "open PO_HomeInsurance" "get HIHL*.csv <1D\" "Close" "Exit"
The other is
winscp.com /Command "Option batch abort" "open PO_LifeInsurance" "get LIHL*.csv <1D\" "Close" "Exit"
However this doesn't work, the only way this works is if I add
LIHL*.csv <1D
into the Transfer setting file mask, but this is global so it isn't what I want.
What am I doing wrong??
Re: Transfer more than 1 file type to different folders
Remove the space before <1D. Also I think the backslash should not be there.
winscp.com /Command "Option batch abort" "open PO_HomeInsurance" "get HIHL*.csv<1D" "Close" "Exit"
Or add double double-quotes around the whole mask:
winscp.com /Command "Option batch abort" "open PO_HomeInsurance" "get ""HIHL*.csv <1D""" "Close" "Exit"
See https://winscp.net/eng/docs/file_mask#size_time
