File conversion issue in WINSCP
Maju
Hi Support Team,
I am facing an issue with WINSCP like follows,
Customer is saying that they are uploading ZIPPED files to sFTP in UTF8 format.
When we download the ZIP files from this sFTP using WINSCP and UNZIP it, sometimes we are getting UTF8 correctly but some times ANSI also getting.
Since our applciation could not support ANSI files, it is making issues and we could not solve this so far.
Is there any chance for file conversion by WINSCP even if the files are inside a ZIP file ?
Thanks in advance.
Maju
Re: File conversion issue in WINSCP
No way. WinSCP does not understand ZIP format.
