rm command in script fails in 5.5.5
Jan Jansen
I found a bug with the command rm in version 5.5.5 for example in the script
open ftp://user:pass@127.0.0.1 -passive=on
cd subdironftp
rm fileonftp.txt
the rm command gets first the properties of the file, but looks into the root folder (MLST /fileonftp.txt, not in the subdironftp. That's why you get the log Can't get attributes of file.... If I use rm subdironftp/fileonftp.txt then it gets the properties, but the delete statement afterwards on the ftp server fails, because it can't find the file subdironftp/subdironftp/fileonftp.txt.
After that I downloaded version 5.6.1 beta, and that works ok with the rm command.
Best regards,
Jan Jansen
Re: rm command in script fails in 5.5.5
Also, can you send me an email, so I can send you back a dev version of WinSCP to test? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Jan Jansen
log file 5.5.5
In the attachments you will find a log with version 5.5.5 and another log with the beta version of 5.6.1
and also the script.
So the problem is allready solved with the beta version.
Thanks for your response.
Best regards,
Jan Jansen.
Description: ftp script wit rm command
Description: log of rm command with version 5.6.1
Description: log of rm command with version 5.5.5
