Get with *.* are downloading also Directories
iZueL
Hello!
I´m having a problem. The home directory of the Ftp contains 30 Folders and some ".xls" files. When I run the following command,
get *.* C:\Temp
, WinSCP is downloading all the .xls files but all the Folders too... The folders name are not containing any "." so I don´t understand why the command is not just downloading the .xls files.
I´m missing something??
(WinSCP 5.5.4)
Re: Get with *.* are downloading also Directories
It's a Windows convention (Or maybe a backward compatibility hack with DOS).
In Windows, the . is not a really part of the file name, just a separator between name and extension. In most cases using name and name. refers to the same file (name without an extension).
Try dir *.* on Windows command line. It behaves identically to WinSCP.
Actually WinSCP is made explicitly to mimic this convention, it's not any side-effect nor bug. See https://winscp.net/eng/docs/file_mask#exceptions
If you want to avoid downloading subdirectories, see:
https://winscp.net/eng/docs/faq_script_non_recursive
