Feedback - I've linked to WinSCP
This is a brilliant program. I remember when you first added a link to your WinSCP at my OpenLinx page. Back in the 1.x's, the program was quite buggy. Now it seems to work beautifully and does everything I could have hoped for. I realize there are lots of feature requests, but provided it does "the job" I think most people will be happy :)
Here's where I've added your link.
By the way, have you considered using UPX compression on your executable? When I compressed your EXE file it went from 2.4 M down to 700 K, and it still appeared to run. If that interests you check out this freeware program:
https://upx.github.io/
- support@pc-tools.net
UPX compression
It is compressed with UPX. WinSCP 2.2 (#122) application has 666 KB :-)
Uncompressed is EXE file is only in installation package. Some people reported that some anti-virus applications consider WinSCP packed with UPX as a virus.
