Moving files with time constraint
rsmallwood
For some reason I can't get the time constraint to work.
This is what I had before (which works fine):
mv iVUpload*.xml archive/
This, however, does not:
mv iVUpload*.xml<2D archive/
It is supposed to move files into the archive folder if they are more than 2 days old.
Anyone know why it doesn't work?
Many thanks
Robin
Re: Moving files with time constraint
Works for me.
Can you be more specific about the problem? Does it fail? Moves all files? Moves no files?
rsmallwood
Well, I had three files:
File 1: modified date of 'yesterday'
File 2: modified date of 3 days ago
File 3 modified date of 4 days ago
None of the files were moved. I was expecting files 2 & 3 to be moved.
Log attached.
Works for me.
rsmallwood wrote:
Log attached.
Well, you are using over 5 years old version of WinSCP. It's quite likely that it does not support time-constraints with mvcommand. Please upgrade and try again.
