Integrating FileOptimizer
Bhavin
Wondering if you ever plan to integrate WinSCP with FileOptimizer by Javier Gutierrez?
FileOptimizer allows you to minify several file types (losslessly) using various compression engines - <invalid hyperlink removed by admin>
Re: Integrating FileOptimizer
Thanks for your suggestion. It's the first time I hear about the FileOptimizer. Will see, if more people ask for this.
