Upload file from perticular local Directory
Nizar
Hi Team,
I am new to WinSCP. I use following script and it works fine to upload test.txt file exists in "winscp554" directory. I want to upload file from local directory "D:\FTP\Upload" instead of "C:\winscp554". Would you please guide me in proper direction?
I am using WinSCP product version 5.5.4.0. Please let me know if you require more info. Thanks in Advance.
C:\winscp554>WinSCP.com /script=FTP_Upload.txt
--------------- FTP_Upload.txt -----------
option batch abort
open sftp://user:password@example.com/
put test.txt
Re: Upload file from perticular local Directory
Just use a full path to the file:
put D:\FTP\Upload\test.txt
Or change local working directory to D:\FTP\Upload. Either before starting WinSCP or from WinSCP script using lcd D:\FTP\Upload.
Nizar
Thanks Martin. I use "lcd D:\FTP\Upload" and it works fine.
But when I change it to the folder name with space it provides error message Too many parameters for command 'lcd'. For example, it provides error message for "lcd D:\MY FTP\Upload". Is there anyway, I can include folder/directory with space?
For you information, I am using WinSCP Portable application (v5.5.4.0).
You need to wrap any path with spaces to double quotes (it does not harm to wrap any path to double quotes).
I.e. lcd "D:\MY FTP\Upload"
