Problem copying file
UncleDave
I am using Version 5.1.8 (Build 3799)
I have a QNAP (TS-110 4.1.0) server with a folder that is shared with both cifs & nfs. I mounted both of these shares on a Debian (jessie) server. Using WinSCP I am unable to copy files to either share. I can copy from a telnet session. I am able to see all files and can apply permissions to the folder. I am also able to delete files from both shares. Just not copy files. The error is:
General failure (server should provide error description)
Error code: 4
Error message from server: Failure
Request code: 18
Please advise.
Dave
Re: Problem copying file
Did you read https://winscp.net/eng/docs/sftp_codes#code_4 ?
