Fail to sync system protected file
First of all, please forgive me my approx english (I'm from France).
Anyway, I've got a little issue while using sync command in a windows script.
The pb is that when the synchro find a system protected file, it fail to sync it but create a same named file in remote or local directory but with a size of 0kb.
I tried to bypass the first encountered error wich makes me fail the sync while finding this type of file but it is somehow a pb for me.
the code is quite simple, just a sync both local remote
called by a bat file wich log it and here's a part of the log :
2014-08-11 09:55:10.207 Starting download of /remotedirectory/Thumbs.db > 2014-08-11 09:55:10.207 TYPE I < 2014-08-11 09:55:10.207 200 Type set to I. > 2014-08-11 09:55:10.207 PASV < 2014-08-11 09:55:10.208 227 Entering Passive Mode (Adress). > 2014-08-11 09:55:10.208 RETR Thumbs.db < 2014-08-11 09:55:10.210 550 Thumbs.db: The system cannot find the file specified. . 2014-08-11 09:55:10.210 Copying files from remote side failed. * 2014-08-11 09:55:10.210 (ExtException) **Copying files from remote side failed.** * 2014-08-11 09:55:10.210 Thumbs.db: The system cannot find the file specified. . 2014-08-11 09:55:10.210 Asking user: . 2014-08-11 09:55:10.210 Error transferring file '/remotedirectory/Thumbs.db'. ("Copying files from remote side failed.","Thumbs.db: The system cannot find the file specified. ") < 2014-08-11 09:55:10.210 Script: Error transferring file '/remotedirectory/Thumbs.db'. < 2014-08-11 09:55:10.210 Script: Copying files from remote side failed. < 2014-08-11 09:55:10.210 Thumbs.db: The system cannot find the file specified. * 2014-08-11 09:55:10.210 (EScpSkipFile) Error transferring file '/remotedirectory/Thumbs.db'. * 2014-08-11 09:55:10.210 Copying files from remote side failed. * 2014-08-11 09:55:10.210 Thumbs.db: The system cannot find the file specified.
