Configure Prompts in Preferences
rcdmk
Brazil
I would like to have a section on the preferences window to auto answer the application prompts like the one spawned when you have synchronization of paths enabled and navigate to a folder on the server that doesn't exists locally.
For example:
A section named "Prompts" that has a list of options like:
- Prompt behavior when sync paths is enabled: (prompt, assume yes, assume no)
- Prompt when transferring files with double click when Copy is selected as double click action: (prompt, assume yes, assume no)
You got the idea.
Thx.
Re: Configure Prompts in Preferences
There is a similar request:
https://winscp.net/tracker/347
That is configurable. See Confirm copy on double-click operation:
https://winscp.net/eng/docs/ui_pref_panels
