How to make winscp automatically accept server host key?
JmenoBezCeskychZnakuBoze
I'm writing a script to transfer data via winscp using its powershell functionality.
I need to use SFTP and automatically accept host key fingerprint on first connection and on all further ones, no matter what is the value.
How do I script that, pls?
When I write a script without specifying hostkey, it throws this back at me:
Exception calling "Open" with "1" argument(s): "SessionOptions.Protocol is Protocol.Sftp or Protocol.Scp, but SessionOptions.HostKey is not set."
I might have phrased it a bit better...
Well, simply. I don't have a fingerprint of that server key and I don't care about changes of the server key. I don't want to use the fingerprint and want to accept the server key automatically without any prompt. How can I suppress the prompt and accept it automatically without having fingerprint?
Re: How to make winscp automatically accept server host key?
Use SessionOptions.GiveUpSecurityAndAcceptAnySshHostKey.
Please read documentation, boze:
https://winscp.net/eng/docs/library_sessionoptions
The link shows syntax for C# and VB.net. I'm running WinSCP from a batch file using command line parameters. Can you set session options in a batch file? An example would be appreciated
In scripting, you can (but should not!) use -hostkey=*
See https://winscp.net/eng/docs/faq_hostkey#automation and https://winscp.net/eng/docs/scriptcommand_open#hostkey
