Cannot focus a disabled or invisible window - Vcl::Forms::TCustomForm::SetFocus
Goto page
1, 2, 3, 4, Next
klonos
Greece
This error came up when I double-clicked on a .txt file on the remote server pane (Ubuntu 13.10 x64 if that matters). Because the download/open dialog took a few seconds before it popped up, I think I tried a single click on the remote pane. At the time of that click, the download/open dialog popped up and the error message too.
WinSCP 5.6.1
[00446F31] Vcl::Forms::TCustomForm::SetFocus
klonos
That's fine. I did not get the error again since and it was a one-timer, so could be a fluke (my OS has not been restarted for over a week).
Will report if it happens again.
djb@...
WinSCP 5.7.1
[0111BDC9] Vcl::Forms::TCustomForm::SetFocus
Re: Cannot focus a disabled or invisible window
mohdfattah@...
WinSCP 5.7.1
[00C4BDC9] Vcl::Forms::TCustomForm::SetFocus
yezhiye94@...
WinSCP 5.7.2
(001DAFAD) Vcl::Forms::TCustomForm::SetFocus
(000103E1) TCustomScpExplorerForm::ExecuteFile
(00010AD2) TCustomScpExplorerForm::ExecuteFile
(0001604D) TCustomScpExplorerForm::DoDirViewExecFile
(00015F22) TCustomScpExplorerForm::DirViewExecFile
(003D9224) Customdirview::TCustomDirView::Execute
(0021B9C9) Vcl::Controls::TWinControl::WndProc
(0025F8F7) Vcl::Comctrls::TCustomListView::WndProc
(0033F8EC) System::Classes::_18201
(000080CC) USER32.DLL
(0000CDD0) USER32.DLL.CallWindowProcW
(0003C83F) COMCTL32.DLL.DefSubclassProc
(0003C821) COMCTL32.DLL.DefSubclassProc
(0002B42B) COMCTL32.DLL
(0003C5F0) COMCTL32.DLL
(003FE4C3) Dragdrop::TDragDrop::WndMethod
(0000966A) USER32.DLL
gispam@...
was deleting a folder in remote window (commander) while downloading master folder (specific folder for deletion had already downloaded completely)
WinSCP 5.7.2
dutchman01@...
WinSCP 5.7.2
djb@...
WinSCP 5.7.2
94Andrey7@...
WinSCP 5.7.2
Трассировка стека:
Re: Cannot focus a disabled or invisible window - Vcl::Forms::TCustomForm::SetFocus
peter@...
SCP into my web server and drag and dropped the complete web site to my local drive.
WinSCP 5.7.3
(001DB4D9) Vcl::Forms::TCustomForm::SetFocus
artleonic@...
WinSCP 5.7.3
Трассировка стека:
Thanks for your reports.
rebornishard@...
WinSCP 5.7.3
(00031A96) TNonVisualDataModule::ExplorerAction"s"Execute
(00381EE0) System::Actions::TContainedActionList::ExecuteAction
(00169A41) Vcl::Actnlist::TCustomAction::Execute
(0033FE18) System::Classes::_18201
(000152F7) USER32.dll
(00015D35) USER32.dll
(000167BF) USER32.dll
shshim@...
WinSCP 5.7.2
I have sent you an email with a debug version of WinSCP to addresses you have used to register on this forum.
ktarbet@...
Low priority: When transferring files, If I click (the 'Once finished' drop down) within the progress dialog, while the transfer completes I get the error. Files were transferred ok. If I leave the progress dialog alone (don't click on it) there is no error.
Steps to reproduce:
1) open a scp connection to remote host
2) drag three files from local directory to remote directory
3) click on the 'once finished' drop down box while the transfer is in progress.
4) when the transfer completes an error is displayed.
WinSCP 5.7.3
Description: error dialog
Description: screen shot
brunda@...
WinSCP 5.7
[0146BD39] Vcl::Forms::TCustomForm::SetFocus
nou4r@...
WinSCP 5.7.2
faisal123@...
WinSCP 5.7.3
(0001606D) TCustomScpExplorerForm::DoDirViewExecFile
(00015F42) TCustomScpExplorerForm::DirViewExecFile
(003D9764) Customdirview::TCustomDirView::Execute
(0021BEF5) Vcl::Controls::TWinControl::WndProc
(0025FE23) Vcl::Comctrls::TCustomListView::WndProc
(0003D15F) COMCTL32.DLL.DefSubclassProc
(0003D141) COMCTL32.DLL.DefSubclassProc
(0002B24C) COMCTL32.DLL
(0003CF10) COMCTL32.DLL
(003FEA3F) Dragdrop::TDragDrop::WndMethod
sashijei@...
WinSCP 5.7.3
(0001FD22) USER32.dll
david@...
Syncronizing remote website to local - mostly file deletions from Local but a few new downloads. It stalled twice ("Lost Connection" "Disconnected from server Copying files from remote side failed") and then this message came up. After clicking Continue it had all files synced except a few and that completed successfully.
WinSCP 5.7.2
behinduhd@...
WinSCP 5.7.4
(001DB64D) Vcl::Forms::TCustomForm::SetFocus
(00010485) TCustomScpExplorerForm::ExecuteFile
(00010B76) TCustomScpExplorerForm::ExecuteFile
(00016111) TCustomScpExplorerForm::DoDirViewExecFile
(00015FE6) TCustomScpExplorerForm::DirViewExecFile
epele@...
WinSCP 5.7.4
Трассировка стека:
zanon.mark@...
Tried to save a txt document after modifying it via ctrl + s. After I hit ctrl + s the status bar (on the taskbar) says "Uploading... 100%" and is green. Whenever I try to close the file it asks me if I want to save, If I click yes the popup closes but the file remains open. If I click no the file closes. At this point if I try to open the file I get the error below and have to restart winscp
I wish I had more information on the bug but it seems pretty random
WinSCP 5.7.4
(00031B32) TNonVisualDataModule::ExplorerActions Execute
(00382054) System::Actions::TContainedActionList::ExecuteAction
(00169BB5) Vcl::Actnlist::TCustomAction::Execute
(0033FF8C) System::Classes::_18201
tihi@...
WinSCP 5.7.4
baoliveira@...
I was deleting a remote file then
1 - clicked minimize button of the delete window
2 - restored the main window
3 - the error message popup
WinSCP 5.7.4
baoliveira@...
1 - delete 2 remote directories
2 - clicked on the "Once Finished" combobox
3 - while the combobox was opened the exception message pop
WinSCP 5.7.4
Thanks. I've aware of this bug. It will be mitigated in the next release by an absence of the combo box.
clach
WinSCP 5.7.4
Trace de la pile :
Trying to find a way (a checkbox) to prevent the transfer progrss wildow from autocloing when finished I opened the scrolldown menu.
The was no "Stay open and wait" option in the list :cry:, BUT
when the app autocloses the progress form, you'll get this error :shock:
cheers
:mrgreen:
junne@...
Dragged a file from desktop to WinSCP file window
WinSCP 5.7.4
cdfiles@...
WinSCP 5.7.1
Трассировка стека:
[014CBDC9] Vcl::Forms::TCustomForm::SetFocus
gecegece@...
WinSCP 5.7.4
(003D98D8) Customdirview::TCustomDirView::Execute
(0021C069) Vcl::Controls::TWinControl::WndProc
(0025FF97) Vcl::Comctrls::TCustomListView::WndProc
(003FEBB3) Dragdrop::TDragDrop::WndMethod
myCreedo98@...
WinSCP 5.7.4
evieler@...
WinSCP 5.7.3
gdawgrancid@...
This is a Windows 10 install, happens only now after I updated to the latest version. WinSCP is just opened and connected into a session. Still have full functionality after hitting ok throuhg the error
WinSCP 5.7.5
(001DB8DD) Vcl::Forms::TCustomForm::SetFocus
andrew631@...
WinSCP 5.7.5
(00031B32) TNonVisualDataModule::ExplorerActionsExecute
(003822E4) System::Actions::TContainedActionList::ExecuteAction
(00169E45) Vcl::Actnlist::TCustomAction::Execute
mymail@...
WinSCP 5.7.4
eppback@...
WinSCP 5.7.5
Yığın izleme:
johansadiri@...
WinSCP 5.7.5
(001DB8DD)
wbrooks634@...
WinSCP 5.7.1
[0145BDC9] Vcl::Forms::TCustomForm::SetFocus
ghazni_baqri@...
WinSCP 5.7.5
(003D9B68) Customdirview::TCustomDirView::Execute
(0021C2F9) Vcl::Controls::TWinControl::WndProc
(00260227) Vcl::Comctrls::TCustomListView::WndProc
(003FEE43) Dragdrop::TDragDrop::WndMethod
maxweishaupl@...
WinSCP 5.7.5
mattaki@...
Finished a transfer, got this message
WinSCP 5.7.5
simon@...
I was synchronizing (direction: remote) a directory on a NTFS partition to a OpenSSH server. I was attempting the dir sync using the UI as the same operation with WinSCP.com keeps failing in the middle of the transfer (says there was a server error).
WinSCP 5.7.5
(001DB8DD)
bdehoff1@...
WinSCP 5.7.5
lozarythmic@...
I was dragging a file (.screenrc) from my google drive folder in windows explorer (Windows 10)
WinSCP 5.7.5
machelle.athon@...
WinSCP 5.7.5
michoo.elrital@...
WinSCP 5.7.4
Coying by a 'Drag&Drop' a folder from remote to local
words@...
WinSCP 5.7.5
window locked into second monitor far right unable to drag from center monitor without error.
jay.connor@...
WinSCP 5.7.3
test@...
I was uploading some files and playing with the field: "once finished" when the bug hit.
WinSCP 5.7.5
jay.connor@... wrote:
WinSCP 5.7.3
venespana159gmail.com
WinSCP 5.7.5
dominikdev@...
WinSCP 5.7.5
kapoue3@...
WinSCP 5.7.5
idhan@...
WinSCP 5.7.5
yoavspector@...
I was in the dropdown menu for what to do when a long delete action was finished, and the action just finished.
WinSCP 5.7.5
apt.get@...
WinSCP 5.7.5
kenrager@...
WinSCP 5.7.5
Transferring roms to raspberry pi
sawymer@...
WinSCP 5.7.4
sawymer@... wrote:
WinSCP 5.7.4
gh@...
WinSCP 5.7.5
Davidbrogli@...
WinSCP 5.7.5
khankakarot@...
WinSCP 5.7.4
(00007731) USER32.dll
(00007811) USER32.dll
(0001900E) USER32.dll
(00019034) USER32.dll.CallWindowProcW
(000079C8) USER32.dll
(00007A0B) USER32.dll.DispatchMessageW
kgmnsh@...
WinSCP 5.7.5
abqsteve@...
I clicked the "once finished" drop down in the downloading window while synchronizing was happening. I have not tried to repro.
WinSCP 5.7.5
trey@...
WinSCP 5.7.5
(00033921) USER32.dll
(0001378B) USER32.dll
(00013522) USER32.dll.CallWindowProcW
(00076D3A) COMCTL32.DLL
(00076D21) COMCTL32.DLL
(00076B5C) COMCTL32.DLL
(0001308C) USER32.dll
haoguoxin5822588@...
WinSCP 5.7.3
(00031A96) TNonVisualDataModule::ExplorerActionsExecute
abotaka.ali@...
WinSCP 5.7.5
gollmer@...
I just finished uploading a file, I don't know what this error does or what produced it (since everything worked fine).
WinSCP 5.7.4
hiteshpamnani.itpro@...
WinSCP 5.7.6
(001DB8F9) Vcl::Forms::TCustomForm::SetFocus
theu0111@...
WinSCP 5.7.6
rjsmith1999@...
WinSCP 5.7.6
I opened winSCP, connected, and hit synchronize. After I clicked ok on the syncronize page I got this error. (Don't know if its repeatable)
autonomycore@...
Deleting a large directory, changed drop down in 'working prompt' from 'stay idle' to 'disconnect'
WinSCP 5.7.5
(001DB8DD)
bmadhu2235@...
WinSCP 5.7.3
tim.t.walker@...
This error came whenI tried a drag & drop from windows explorer to o\WinSCP explorer.
WinSCP 5.7.6
hendriksutrisna@...
WinSCP 5.7.6
(0001048D) TCustomScpExplorerForm::ExecuteFile
(00010B7E) TCustomScpExplorerForm::ExecuteFile
(00016119) TCustomScpExplorerForm::DoDirViewExecFile
(00015FEE) TCustomScpExplorerForm::DirViewExecFile
(003D9BA4) Customdirview::TCustomDirView::Execute
(0021C315) Vcl::Controls::TWinControl::WndProc
(00260243) Vcl::Comctrls::TCustomListView::WndProc
(003FEE7F) Dragdrop::TDragDrop::WndMethod
jennie@...
WinSCP 5.7.5
Goto page
1, 2, 3, 4, Next
