v 5.6.1, SFTP: copy to server does not work for an hour
dominik
I would wish myself for FTP a manual local-remote-timestamp-difference adjustment.
Strangely, in command line mode, everything works like a charm with keepuptodate.
But in GUI mode, you have always during summer, with DST in place, after the first upload of a file to be worked on, that the local file looks an hour older than the remote and WSCP refuses to upload.
With SFTP, you can fortunately choose -server -edit -advanced -adjust remote timestamp with DST.
Thanks for wscp -
Dominik
Re: v 5.6.1, SFTP: copy to server does not work for an hour
Can you attach a log files from scripting and GUI showing how it behaves differently?
