file panel font should not be linked to icon font
Ninetrees
It should be available in preferences. This is not a feature request, it is a bug report. I don't need to see my icon text very often... that's what the icons are for. So I HAD it small enough to minimize text space, and large enough to read if I need to. That same reasoning does not apply to the file panel, where there are no images to focus on. I had to change my icon font for /just one app/ --- this one. That's not right. I know of other apps that have linked some important text to icon size, and I just don't get that.
~R~
Re: file panel font should not be linked to icon font
While the setting may be called "Icons" font in Windows, it's used even for "Details" view in Windows Explorer, what is an identical view to WinSCP file panels. So it's definitely not a bug.
Anyway, this request is tracked here:
https://winscp.net/tracker/596
