Include/Exclude specific File using synchronize with -filema
is it possible to Include or Exclude some specific Files before using synchronize with -filemask ??
EX:
I want to exclude some specific files before getting synchronized to avoid them to be uploaded, for this example if exist BFFXA018.exe or CFFXA016.exe, they shouldnt be synchronized even the filemask is set for *.exe
CODE:
option echo on
option batch on
option exclude "BFFXA018.exe;CFFXA016.exe; /*"
# Connect to FTP
# Synchronize DIAGS
synchronize local -filemask="*.exe>1D|archive/" D:\fsdash\diags\SYNCdev\bin\temp\SYNC /diags/SYNC
THX
EX:
CODE:
option echo on
option batch on
# Connect to FTP
# Synchronize DIAGS
THX
