WinSCP process terminated with exit code 3 and output ""
Yaco91
Ecuador
Error Find:
WinSCP process terminated with exit code 3 and output "",
without responding
(response log file C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\wscp102C.03CE0BB8.tmp was not created).
This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
at WinSCP.Session.Open(SessionOptions sessionOptions)
Please Help.?
Re: WinSCP process terminated with exit code 3 and output ""
First, we need to know all information about the environment that you use WinSCP in.
qiqiweige
Win 7 ,Visual Studio 2010 C# console application
qiqiweige
How to set winscp.dll and winscp.exe?when i debug my project ,it will throw the "WinSCP process terminated with exit code 3 and output "", without responding (response log file C:\Users\Administrator\AppData\Local\Temp\wscp1664.02B89EAA.tmp was not created). This could indicate lack of write permissions to the log folder or problems starting WinSCP itself."
qiqiweige
Can i send my Project to you and you help me to check my setting?
