WinSCP 5.5.4 file download problem
LoganGuy
When I download Linux tar files to Windows 7 they have a filesize the same as the Linux tar but the tar is empty. This was not happening before and I have not changed WinSCP. I can extract the tar in Linux without a problem. What setting do I need to change? The tar file is created by drush archive:dump. BTW, the tar file is about 29MB.
Regards
Re: Winscp 5.5.4
Re: Winscp 5.5.4
I do not see anything wrong in the log. Did you try to compare checksum of local and remote file?
