data file content and log file are inverted
ericgibert@yahoo.fr
Here is a normal LOG file content:. 2014-07-23 09:49:05.495 File: '/Singapore_PRD/OUTBOX/PICKCFM/SGZME19140722205717.txt' [2014-07-22T13:02:01.000Z] [651]
. 2014-07-23 09:49:05.495 Copying "/Singapore_PRD/OUTBOX/PICKCFM/SGZME19140722205717.txt" to local directory started.
. 2014-07-23 09:49:05.495 Binary transfer mode selected.
. 2014-07-23 09:49:05.495 Starting download of /Singapore_PRD/OUTBOX/PICKCFM/SGZME19140722205717.txt
> 2014-07-23 09:49:05.495 TYPE I
. 2014-07-23 09:49:05.729 TLS connection established
. 2014-07-23 09:49:05.760 type=dir;size=512;modify=20140723014909;create=20110214015705;perm=ceflp; .
. 2014-07-23 09:49:05.760 type=dir;size=512;modify=20140723014909;create=20110214015705;perm=ceflp; ..
. 2014-07-23 09:49:05.760 type=file;size=651;modify=20140722130201;create=20140722130201;perm=adfrw; SGZME19140722205717.txt
but once in a while, we have in the LOG file:
> 2014-07-23 09:48:58.276 RETR SGZME19140722205201.txt
. 2014-07-23 09:48:58.526 Loading system certificates
. 2014-07-23 09:48:58.542 Main TLS session ID was not reused previously, not trying again
. 2014-07-23 09:48:58.542 TLS layer changed state from none to connected
< 2014-07-23 09:48:58.542 150 File status okay; about to open data connection.
< 2014-07-23 09:48:58.776 150 Opening BINARY mode data connection for SGZME19140722205201.txt (2601 bytes).
. 2014-07-23 09:48:58.792 Loading system certificates
. 2014-07-23 09:48:58.792 Main TLS session ID was not reused previously, not trying again
. 2014-07-23 09:48:58.792 TLS layer changed state from none to connected
. 2014-07-23 09:49:00.057 TLS connection established
. 2014-07-23 09:49:00.151 H CPD 2600467864 20140722 20140723 20140722 000010 Z0169800 2 T
. 2014-07-23 09:49:00.151 H CPD 2600467864 20140722 20140723 20140722 000020 G1429800 3 T
The last two lines are the DATA file content!
and the data file receive the LOG file messages:
type=dir;size=512;modify=20140723014615;create=20110214015233;perm=ceflp; .
type=dir;size=512;modify=20140723014615;create=20110214015233;perm=ceflp; ..
type=file;size=97;modify=20140722143505;create=20140722144306;perm=adfrw; STID140722093505.txt
in other words, the LOG output is redirected to the data file, while the data content is redirect to the LOG file.
Note: execution by script, FTPS protocole is used, BINARY mode is forced. Winscp Version 5.5.3.
Anyone experienced the same mixed up? Any suggestions?
Thank you
Eric
Re: data file content and log file are inverted
None of the logs actually look normal to me.
