5.6 beta - Invalid access to memory for custom commands
Ricardo
Ricardo avatar
5.6 beta - Invalid access to memory when trying to run custom commands (SSH session).
(Screenshot attached)
And using the opportunity for some other bugs I was holding for reporting:
  1. I'm not sure, but shouldn't "Open Session in Putty" be disabled for FTP?
  2. New FTP sessions inherit options from default session settings if it is SFTP type, e.g., tunnel options.
Ricardo
Ricardo avatar
Yes, it is fixed. Thanks!
Perhaps do you have any comment about this?:
meckardt
Deutschland
Re: 5.6 beta - Invalid access to memory for custom commands
Can you please send me a dev version too? I'm facing the same bug. Thanks
It's probably due to this bug:
https://winscp.net/tracker/1187
I'm sending you dev version to verify that it's fixed.
Ricardo
Ricardo avatar
I hope he release 5.6.1 asap, it seems that many people is facing that bug...
It takes some days until he read new forum posts, though.
Sorry, I've overlooked these.
WinSCP uses telnet (not SSH) by default for FTP sessions.
See https://winscp.net/eng/docs/ui_pref_integration_app
I know that it's unlikely that it actually works. But it may for someone, so why do not give it a chance?
Yes. But the setting is not used for FTP session, right?
And it may be working one day:
https://winscp.net/tracker/40
Sent.
WinSCP 5.6.1 beta will be released early next week.
