Remote directory setting (WebDAV) not supporting utf8
fschroedter
The enviroment settings "remote directory" of the WebDAV protocoll does not support utf8.
My directory "/Eingebundene Ordner/Team-Δ" is stored as "/Eingebundene Ordner/Team-?". When this wrong directory was remembered the next login fails. :(
Re: Remote directory setting (WebDAV) not supporting utf8
Though I was not able to reproduce your problem.
fschroedter
I determined that this problem can not be logged because the failure happens before connecting a server. Moreover this problem is independent from the protocol.
How to reproduce:
1. Start WinSCP and create new a session. (keep session details empty)
2. Set remote directory to "/Team-Δ".
3. Save session.
4. Restart WinSCP.
5. Check the remote directory. I see "/Team-?".
Tested on WinSCP 5.5.4 portable and 5.6 beta.
Description: Set remote directory to "/Team-Δ"
Description: Stored remote directory after WinSCP was restarted.
