Error trying to download file
samc
I receive an error while trying to download a file. I have no logs and I don't know how to log. If someone could show me how to log, then I will provide that.
Error:
Exception calling "Check" with "0" argument(s): "Can't get attributes of file
'LYLI_20140708_180540.TXT'."
At line:11 char:4
+    $session.GetFiles($Fileinfo, $LocalPath).Check()
    + CategoryInfo          : NotSpecified: (:) [], MethodInvocationException
    + FullyQualifiedErrorId : SessionRemoteException
My code:
# Load WinSCP .NET assembly
# Setup session options
$sessionOptions.Protocol = [WinSCP.Protocol]::ftp
$sessionOptions.HostName = "server"
$sessionOptions.UserName = "user"
$sessionOptions.Password = "pass"
$RemotePath = "/EXPORT/LYKA_$($date)_*/"
$LocalPath = "C:\Users\samc\Desktop\FTP\$Fileinfo"
$date = Get-Date -Year 2014 -Month 07 -Day 08 -Format yyyyMMdd
$wildcard = "LYLI*.txt"
$directoryInfo = $session.ListDirectory("/EXPORT/")
$files = $directoryInfo.Files | ?{$_.name -match "LYLI_$date"}
foreach ($Fileinfo in $files) {
   Write-Host ($fileinfo.Name)
samc
LOG for doing it with GUI. There are a lot more files. Didnt want to clog up the forum.
. 2014-07-11 14:16:24.527 --------------------------------------------------------------------------
. 2014-07-11 14:16:24.527 WinSCP Version 5.5.4 (Build 4433) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2014-07-11 14:16:24.527 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2014-07-11 14:16:24.527 Local account: PRIMROSE\samc
. 2014-07-11 14:16:24.527 Working directory: C:\Program Files (x86)\WinSCP
. 2014-07-11 14:16:24.527 Process ID: 3376
. 2014-07-11 14:16:24.527 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2014-07-11 14:16:24.527 Time zone: Current: GMT+1, Standard: GMT+0 (GMT Standard Time), DST: GMT+1 (GMT Daylight Time), DST Start: 30/03/2014, DST End: 26/10/2014
. 2014-07-11 14:16:24.528 Login time: 11 July 2014 14:16:24
. 2014-07-11 14:16:24.528 --------------------------------------------------------------------------
. 2014-07-11 14:16:24.528 Session name: FTP (Site)
. 2014-07-11 14:16:24.528 Host name: 79.171.178.50 (Port: 21)
. 2014-07-11 14:16:24.528 User name: PRIMROSE (Password: No, Key file: No)
. 2014-07-11 14:16:24.528 Tunnel: No
. 2014-07-11 14:16:24.528 Transfer Protocol: FTP
. 2014-07-11 14:16:24.528 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2014-07-11 14:16:24.528 Proxy: none
. 2014-07-11 14:16:24.528 Send buffer: 262144
. 2014-07-11 14:16:24.528 UTF: 2
. 2014-07-11 14:16:24.528 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2014-07-11 14:16:24.528 Local directory: C:\Program Files (x86)\WinSCP, Remote directory: /, Update: Yes, Cache: Yes
. 2014-07-11 14:16:24.528 Cache directory changes: Yes, Permanent: Yes
. 2014-07-11 14:16:24.528 DST mode: 1; Timezone offset: 0h 0m
. 2014-07-11 14:16:24.588 Connecting to ********* ...
. 2014-07-11 14:16:24.690 Connected with *********. Waiting for welcome message...
< 2014-07-11 14:16:24.717 220 edi FTP server (IS FTP-Service, version 5.7.31) ready.
> 2014-07-11 14:16:24.717 USER PRIMROSE
< 2014-07-11 14:16:24.753 331 Password required for PRIMROSE (f78f875b735e37c7).
> 2014-07-11 14:16:35.598 PASS ************
< 2014-07-11 14:16:35.740 230 User PRIMROSE logged in.
> 2014-07-11 14:16:35.740 SYST
< 2014-07-11 14:16:35.950 215 UNIX Type: L8 Version: IS 5.7.31
> 2014-07-11 14:16:35.950 FEAT
< 2014-07-11 14:16:36.248 211-Extensions supported:
< 2014-07-11 14:16:36.248 CLNT
< 2014-07-11 14:16:36.248 AUTH TLS
< 2014-07-11 14:16:36.248 PBSZ
< 2014-07-11 14:16:36.248 PROT
< 2014-07-11 14:16:36.248 MDTM
< 2014-07-11 14:16:36.248 MFMT
< 2014-07-11 14:16:36.248 PASV
< 2014-07-11 14:16:36.248 REST STREAM
< 2014-07-11 14:16:36.249 SIZE
< 2014-07-11 14:16:36.249 XCRC "Filename" SP EP
< 2014-07-11 14:16:36.249 XMD5 "Filename" SP EP
< 2014-07-11 14:16:36.249 XSH1 "Filename" SP EP
< 2014-07-11 14:16:36.249 211 End.
. 2014-07-11 14:16:36.299 Connected
. 2014-07-11 14:16:36.299 --------------------------------------------------------------------------
. 2014-07-11 14:16:36.299 Using FTP protocol.
. 2014-07-11 14:16:36.299 Doing startup conversation with host.
> 2014-07-11 14:16:36.350 PWD
< 2014-07-11 14:16:36.721 257 "/" is current directory.
. 2014-07-11 14:16:36.751 Changing directory to "/".
> 2014-07-11 14:16:36.751 CWD /
< 2014-07-11 14:16:37.173 250 CWD command successful.
. 2014-07-11 14:16:37.173 Getting current directory name.
> 2014-07-11 14:16:37.173 PWD
< 2014-07-11 14:16:37.517 257 "/" is current directory.
. 2014-07-11 14:16:37.702 Retrieving directory listing...
> 2014-07-11 14:16:37.702 TYPE A
< 2014-07-11 14:16:38.001 200 Type set to A.
> 2014-07-11 14:16:38.002 PASV
< 2014-07-11 14:16:38.470 227 Entering Passive Mode (79,171,178,50,224,246)
> 2014-07-11 14:16:38.470 LIST -a
< 2014-07-11 14:16:38.914 150 ASCII data connection for / (212.58.48.107,57590).
. 2014-07-11 14:16:38.914 drw-rw-rw- 3 generic 4096 Jul 11 15:15 IMPORT
. 2014-07-11 14:16:38.914 drw-rw-rw- 3 generic 49152 Jul 11 15:06 EXPORT
< 2014-07-11 14:16:39.151 226 ASCII transfer complete.
. 2014-07-11 14:16:39.153 Directory listing successful
. 2014-07-11 14:16:39.153 ..;D;0;1899-12-30T00:00:00.000Z;"" [0];"" [0];---------;0
. 2014-07-11 14:16:39.153 IMPORT;D;4096;2014-07-11T14:15:00.000Z;"generic" [0];"" [0];rw-rw-rw-;1
. 2014-07-11 14:16:39.153 EXPORT;D;49152;2014-07-11T14:06:00.000Z;"generic" [0];"" [0];rw-rw-rw-;1
. 2014-07-11 14:16:39.253 Startup conversation with host finished.
. 2014-07-11 14:17:03.085 Changing directory to "IMPORT".
> 2014-07-11 14:17:03.085 CWD IMPORT
< 2014-07-11 14:17:03.117 250 CWD command successful.
. 2014-07-11 14:17:03.117 Getting current directory name.
> 2014-07-11 14:17:03.117 PWD
< 2014-07-11 14:17:03.148 257 "/IMPORT" is current directory.
. 2014-07-11 14:17:03.148 Retrieving directory listing...
> 2014-07-11 14:17:03.148 TYPE A
< 2014-07-11 14:17:03.179 200 Type set to A.
> 2014-07-11 14:17:03.180 PASV
< 2014-07-11 14:17:03.234 227 Entering Passive Mode (79,171,178,50,146,163)
> 2014-07-11 14:17:03.234 LIST -a
. 2014-07-11 14:17:03.293 <Empty directory listing>
< 2014-07-11 14:17:03.295 150 ASCII data connection for /IMPORT (212.58.48.107,37539).
< 2014-07-11 14:17:03.525 226 ASCII transfer complete.
. 2014-07-11 14:17:03.525 Directory listing successful
. 2014-07-11 14:17:03.525 ..;D;0;1899-12-30T00:00:00.000Z;"" [0];"" [0];---------;0
. 2014-07-11 14:17:06.009 Cached directory change via ".." to "/".
. 2014-07-11 14:17:06.009 Getting current directory name.
. 2014-07-11 14:17:06.011 Directory content loaded from cache.
. 2014-07-11 14:17:06.733 Changing directory to "EXPORT".
. 2014-07-11 14:17:06.733 Synchronizing current directory "/".
> 2014-07-11 14:17:06.733 CWD /
< 2014-07-11 14:17:06.764 250 CWD command successful.
> 2014-07-11 14:17:06.765 CWD EXPORT
< 2014-07-11 14:17:06.796 250 CWD command successful.
. 2014-07-11 14:17:06.796 Getting current directory name.
> 2014-07-11 14:17:06.796 PWD
< 2014-07-11 14:17:06.827 257 "/EXPORT" is current directory.
. 2014-07-11 14:17:06.827 Retrieving directory listing...
> 2014-07-11 14:17:06.827 TYPE A
< 2014-07-11 14:17:06.859 200 Type set to A.
> 2014-07-11 14:17:06.859 PASV
< 2014-07-11 14:17:06.911 227 Entering Passive Mode (79,171,178,50,189,221)
> 2014-07-11 14:17:06.911 LIST -a
< 2014-07-11 14:17:06.991 150 ASCII data connection for /EXPORT (212.58.48.107,48605).
< 2014-07-11 14:17:07.389 226 ASCII transfer complete.
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 47 Apr 08 11:06 LYBU_20140408_110539.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 15722 Jun 12 17:06 LYPA_20140612_170537.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 660 Apr 08 11:06 LYPA_20140408_110549.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 68955 Apr 30 09:05 LYPA_20140430_090501.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 110398 Apr 29 09:06 LYPA_20140429_090520.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 5519 May 19 09:06 LYPA_20140519_090553.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 40493 May 26 13:06 LYPA_20140526_130520.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 3224 Apr 14 17:05 LYPA_20140414_170501.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 11410 Jun 19 06:01 LYBV_20140619_060036.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 5318 May 01 12:06 LYPA_20140501_120559.TXT
. 2014-07-11 14:30:07.446 -rw-rw-rw- 1 generic 70340 May 08 09:06 LYPA_20140508_090551.TXT
. 2014-07-11 14:30:07.446 Directory listing successful
> 2014-07-11 14:30:37.757 TYPE A
< 2014-07-11 14:30:37.757 200 Type set to A.
. 2014-07-11 14:30:59.113 File: '/EXPORT/LYLI_20140708_180540.TXT' [2014-07-08T17:06:00.000Z] [620]
. 2014-07-11 14:30:59.129 Copying "/EXPORT/LYLI_20140708_180540.TXT" to local directory started.
. 2014-07-11 14:30:59.129 Binary transfer mode selected.
. 2014-07-11 14:30:59.129 Starting download of /EXPORT/LYLI_20140708_180540.TXT
> 2014-07-11 14:30:59.129 TYPE I
< 2014-07-11 14:30:59.176 200 Type set to I.
> 2014-07-11 14:30:59.176 PASV
< 2014-07-11 14:30:59.223 227 Entering Passive Mode (79,171,178,50,230,12)
> 2014-07-11 14:30:59.223 RETR LYLI_20140708_180540.TXT
< 2014-07-11 14:30:59.316 150 Binary data connection for /EXPORT/LYLI_20140708_180540.TXT (212.58.48.107,58892) (620 bytes).
< 2014-07-11 14:30:59.550 226 Binary transfer complete.
. 2014-07-11 14:30:59.566 Download successful
This is resolved. I used a different method.
$date = Get-Date -Format yyyyMMdd
$Files = $directoryInfo.Files | ?{$_.name -match "LYLI_$date"} | select -ExpandProperty name
$RemotePath = "/EXPORT/$Files"
$LocalPath = "C:\Users\samc\Desktop\FTP\$Files"
Try{
if ($session.FileExists($RemotePath)) {
Write-Host ("File {0} exists" -f $RemotePath)
$session.GetFiles($RemotePath, $LocalPath).Check()
else { Write-Host "File not availiable" }
catch [Exception]{
Write-Host $_.Exception.Message
Re: Error trying to download file
In your code above, the $Fileinfo is an object of type RemoteFileInfo, while Session.GetFiles expects a string. PowerShell implicitly converts the object to a script by calling .ToString() method that is implemented by RemoteFileInfo to return Name. But Name is file name only, without a path. That's why .GetFiles fails, because it's not able to find the file without knowing its path.
