Transfer Fails - Error Code 14 Request Code 6 - No Space
50PUYN
Melbourne, AUS
Hi all,
I'll be as succinct at possible
Scenario:
Trying to copy a 5 gig file over FTP. I have an SSIS package to do this. I have also tried it using Winscp.exe through command prompt. In both cases I get an error saying that No space available on the remote side. It will copy 95% of the file and fail. (See log file dump below)
I am executing WinSCP using the following parameters:
option batch abort
open sftp://xxx:xxxxx@255.255.255.2555 -rawsettings SendBuf=0 -hostkey="ssh-rsa 1024 e4:dd:11:2e:82:34:ab:62:59:1c:c8:62:1d:4b:48:99"
put F:\TEMP_DG\Test_SFTP.bak Test_SFTP.bak
close
I thought maybe it’s some restriction in WinSCP in terms of the file size that can be sent.
However, using the GUI interface of WinSCP I can copy the file over no problem, no errors, no complaints.
Please help because I am really out of ideas here.
Thanks.
> 2014-07-10 11:49:39.350 Script: option transfer binary
< 2014-07-10 11:49:39.350 Script: transfer binary
> 2014-07-10 11:49:39.350 Script: put F:\RDNS_SFTP\RDNS_COPY_ONLY_TEST.bak /
. 2014-07-10 11:49:39.350 Copying 1 files/directories to remote directory "/"
. 2014-07-10 11:49:39.350 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2014-07-10 11:49:39.350 TM: B; ClAr: No; CPS: 0; InclM:
. 2014-07-10 11:49:39.350 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2014-07-10 11:49:39.350 File: "F:\RDNS_SFTP\RDNS_COPY_ONLY_TEST.bak"
. 2014-07-10 11:49:39.352 Copying "F:\RDNS_SFTP\RDNS_COPY_ONLY_TEST.bak" to remote directory started.
. 2014-07-10 11:49:39.352 Binary transfer mode selected.
. 2014-07-10 11:49:39.352 Checking existence of file.
> 2014-07-10 11:49:39.352 Type: SSH_FXP_LSTAT, Size: 37, Number: 263
< 2014-07-10 11:49:39.357 Type: SSH_FXP_STATUS, Size: 32, Number: 263
< 2014-07-10 11:49:39.357 Status code: 2
. 2014-07-10 11:49:39.357 Checking existence of partially transfered file.
> 2014-07-10 11:49:39.357 Type: SSH_FXP_LSTAT, Size: 46, Number: 519
< 2014-07-10 11:49:39.361 Type: SSH_FXP_STATUS, Size: 32, Number: 519
< 2014-07-10 11:49:39.361 Status code: 2
. 2014-07-10 11:49:39.361 Opening remote file.
> 2014-07-10 11:49:39.361 Type: SSH_FXP_OPEN, Size: 63, Number: 771
< 2014-07-10 11:49:39.368 Type: SSH_FXP_HANDLE, Size: 13, Number: 771
> 2014-07-10 11:49:39.368 Type: SSH_FXP_WRITE, Size: 4121, Number: 1286
< 2014-07-10 11:54:53.412 Status code: 14, Message: 4008710, Server: No space available., Language: en
. 2014-07-10 11:54:56.501 31935 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2014-07-10 11:54:56.501 Type: SSH_FXP_CLOSE, Size: 13, Number: 4089092
< 2014-07-10 11:54:56.563 Type: SSH_FXP_STATUS, Size: 27, Number: 4089092
< 2014-07-10 11:54:56.563 Status code: 0
* 2014-07-10 11:54:56.563 (ECommand) Copying files to remote side failed.
* 2014-07-10 11:54:56.563 There is no free space on the filesystem.
* 2014-07-10 11:54:56.563 Error code: 14
* 2014-07-10 11:54:56.563 Error message from server (en): No space available.
* 2014-07-10 11:54:56.563 Request code: 6
< 2014-07-10 11:54:56.563 Script: Copying files to remote side failed.
< 2014-07-10 11:54:56.563 Script: There is no free space on the filesystem.
< 2014-07-10 11:54:56.563 Error code: 14
< 2014-07-10 11:54:56.563 Error message from server (en): No space available.
< 2014-07-10 11:54:56.563 Request code: 6
. 2014-07-10 11:54:56.563 Script: Failed
. 2014-07-10 11:54:56.563 Script: Exit code: 1
. 2014-07-10 11:54:56.563 Closing connection.
. 2014-07-10 11:54:56.563 Sending special code: 12
. 2014-07-10 11:54:56.564 Sent EOF message
Re: Transfer Fails - Error Code 14 Request Code 6 - No Space
Well, the error come from the server. There's no restriction on WinSCP side.
Possibly you are using a different account with lower disk quota in the script than in the GUI?
50PUYN
Melbourne, AUS
Hi Martin,
Thank you for you reply first of all.
Unfortunately it is not the case, I used the same account to run the SSIS/Cmd Prompt jobs as I did using the GUI.
The FTP is set up to allow for 20 gig of transfer per user, per day.
The only parameter, that I know of, that I used in the GUI that is different to the parameters that are in the script is a timeout parameter (have it as 120 seconds in the GUI).
So, again I'm stuck with the problem, why it works in GUI and not in anything else?
Is there maybe a way to get the default parameters that the GUI program executes with, and perhaps I could put those into my script and see if that works.
This cannot be about parameter. Only think I can image that can make such difference is that you use FTP in the GUI, while SFTP in the script or something similar.
Please attach a complete log file both from GUI and the script.
