Copying files from remote side failed
I have a script that runs, does run and is able to copy files but fails on certain files and I can't figure out what is going on. Below is the last part of the log when it fails.
< 2014-07-04 18:05:16.789 200 Type set to I. > 2014-07-04 18:05:16.789 PASV < 2014-07-04 18:05:16.819 227 Entering Passive Mode (*,*,*,*,*,*). . 2014-07-04 18:05:16.819 Can't open file 'g:\Documents\manager\manager\Narrative Appraisal\Vince\105 Schelter Update\old\https___lookingglass.streamlinx.com_FileServlet_filename=_apps_tomcat14_webapps_lgs_temp_1337101802133_7F1A3F920BB2B3939F67D759FC877406__05152012_01_10_PM_EngagementLetter_140501.pdf'. . 2014-07-04 18:05:16.819 Copying files from remote side failed. * 2014-07-04 18:05:16.820 (ExtException) **Can't open file 'g:\Documents\manager\manager\Narrative Appraisal\Vince\105 Schelter Update\old\https___lookingglass.streamlinx.com_FileServlet_filename=_apps_tomcat14_webapps_lgs_temp_1337101802133_7F1A3F920BB2B3939F67D759FC877406__05152012_01_10_PM_EngagementLetter_140501.pdf'.** * 2014-07-04 18:05:16.820 Copying files from remote side failed. . 2014-07-04 18:05:16.820 Asking user: . 2014-07-04 18:05:16.820 Error transferring file '/Documents/manager/manager/Narrative Appraisal/Vince/105 Schelter Update/old/https___lookingglass.streamlinx.com_FileServlet_filename=_apps_tomcat14_webapps_lgs_temp_1337101802133_7F1A3F920BB2B3939F67D759FC877406__05152012_01_10_PM_EngagementLetter_140501.pdf'. ("Can't open file 'g:\Documents\manager\manager\Narrative Appraisal\Vince\105 Schelter Update\old\https___lookingglass.streamlinx.com_FileServlet_filename=_apps_tomcat14_webapps_lgs_temp_1337101802133_7F1A3F920BB2B3939F67D759FC877406__05152012_01_10_PM_EngagementLetter_140501.pdf'.","Copying files from remote side failed.") < 2014-07-04 18:05:16.820 Script: Error transferring file '/Documents/manager/manager/Narrative Appraisal/Vince/105 Schelter Update/old/https___lookingglass.streamlinx.com_FileServlet_filename=_apps_tomcat14_webapps_lgs_temp_1337101802133_7F1A3F920BB2B3939F67D759FC877406__05152012_01_10_PM_EngagementLetter_140501.pdf'. < 2014-07-04 18:05:16.820 Script: Can't open file 'g:\Documents\manager\manager\Narrative Appraisal\Vince\105 Schelter Update\old\https___lookingglass.streamlinx.com_FileServlet_filename=_apps_tomcat14_webapps_lgs_temp_1337101802133_7F1A3F920BB2B3939F67D759FC877406__05152012_01_10_PM_EngagementLetter_140501.pdf'. < 2014-07-04 18:05:16.820 Copying files from remote side failed. * 2014-07-04 18:05:16.821 (EScpSkipFile) Error transferring file '/Documents/manager/manager/Narrative Appraisal/Vince/105 Schelter Update/old/https___lookingglass.streamlinx.com_FileServlet_filename=_apps_tomcat14_webapps_lgs_temp_1337101802133_7F1A3F920BB2B3939F67D759FC877406__05152012_01_10_PM_EngagementLetter_140501.pdf'. * 2014-07-04 18:05:16.821 Can't open file 'g:\Documents\manager\manager\Narrative Appraisal\Vince\105 Schelter Update\old\https___lookingglass.streamlinx.com_FileServlet_filename=_apps_tomcat14_webapps_lgs_temp_1337101802133_7F1A3F920BB2B3939F67D759FC877406__05152012_01_10_PM_EngagementLetter_140501.pdf'. * 2014-07-04 18:05:16.821 Copying files from remote side failed. . 2014-07-04 18:05:16.823 Script: Failed . 2014-07-04 18:05:16.823 Script: Exit code: 1 . 2014-07-04 18:05:16.825 Disconnected from server
