local pane has File Folders sorted to the top
micheleiannon
Texas
Is there a way to prevent File Folders from being sorted to the top? They appear first, regardless of what field I sort on. This is very annoying... I have a file I replace every day, and I have to scroll down on the Local pane to get to the Files in order to drag it over from Remote .. otherwise it puts it in whatever File Folder I happen to land on.
I'm using WinSCP v 5.5.3 ... Commander mode with Local on the left, Remote on the right.
Re: local pane has File Folders sorted to the top
Yes, WinSCP always sorts directories to the top. This can be (optionally) changed, if more people ask for.
am2605
I'd like to see this too, as I regularly sort by change date to find the files changed most recently, and would much prefer the folders to be sorted at the bottom.
StefanAuracher
Re: please add don't sort folders before files
micheleiannon wrote:
Is there a way to prevent folders from being sorted to the top? In options/Preferences/Panels dialog under "Use natural order numerical sorting" please add an additional item "don't sort folders before files" this is possibly in almost all Linux filemanagers and I use it all the time
