Can't open connection with desktop icon, but with stored ses
kpw
here are the facs:
Winscp version: 5.5.4 (Build 4433) Portable
Windows version: 8.1 Prof.
FTP-Server: Filezilla 0.9.45 (installed on local machine)
Protocol: ftp
The situation is:
I have configured a session to the local running ftp server (test environment). If I first start client, choose saved session everything works well, session will be established.
I have created a desktop shortcut for the session. If I try to connect via desktop icon I get a message saying
"Connection to host rejected. Server denied SFTP connection but is listening on ftp-port. Do you want to connect via ftp? You should use a crypted connection".
On filezilla console I get the following message:
(000049)02.07.2014 21:12:40 - (not logged in) (10.0.2.15)> Connected, sending welcome message...
(000049)02.07.2014 21:12:40 - (not logged in) (10.0.2.15)> 220-FileZilla Server version 0.9.45 beta
(000049)02.07.2014 21:12:40 - (not logged in) (10.0.2.15)> 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
(000049)02.07.2014 21:12:40 - (not logged in) (10.0.2.15)> could not send reply, disconnected.
I don't use a proxy. I have configured fire wall, if fire wall was the problem I wouldn't be able to connect via client. Why does the desktop icon try to connect via sftp, I have configured ftp in the session? What can I do?
Thanks for your help und best regards
KPW
KPW
Workaround found
Well, I think it's a bug. You can make it work by exporting the configuration and using the /ini parameter. This workaround fits my requirements, maybe yours too.
Regards KPW
Re: Can't open connection with desktop icon, but with stored ses
WinSCP instance started by the shortcut obviously does not use the same configuration as the instance you have used to save the site.
Can you enable logging and attach a complete log file both for session opened from GUI and from shortcut?
kpw
Here we are
thanks for reply. I've attached the files. You can see that start from gui has set Parameter /ini automatically, start from Icon doesn't. I created the icon with the gui function "create Desktop Icon" and failed. I only added Parameter /log for getting a log file.
Regards
KPW
  • StartFromGUI.txt (4.83 KB, Private file)
Re: Here we are
OK, so you have a desktop shortcut to start WinSCP with explicit /ini switch to make it use INI file in non-standard location, right?
There's request to make shortcuts to sessions use the same configuration as creating instance:
https://winscp.net/tracker/941
