Cannot open a local folder by right click and select 'open'
cindycc
Hello~
Recently I reinstalled my laptop and installed the newest version winscp, I found I can't open a folder to explorer window. Before that, when i right click on a folder, and choose 'open', an explorer window will pop up for this folder. But now the 'open' option is not selectable.
Does anyone know why is that..?
Thanks in advance!!
Cindy
Re: Cannot open a local folder by right click and select 'open'
Since 5.2, WinSCP uses its internal context menu for local files by default, instead of system menu:
https://winscp.net/tracker/163
WinSCP command Open does not work for directories.
So access system Open command, use System Menu command in WinSCP internal context menu (the last entry).
Forgot to mention that you can open directory in Windows Explorer using Open > Go To > Explore Directory or Ctrl+Alt+E shortcut (in Commander interface only, obviously).
HoldOffHunger
that fixed it!
Downgrade to WinSCP 5.17 and this problem disappears entirely. Thanks! (Make sure to disable updating when you install.)
Re: that fixed it!
There's no problem. It's just a different default.
You can always opt to Use system context menu by default in preferences:
https://winscp.net/eng/docs/ui_pref_panels_local
Or use the Open > Go To > Explore Directory command as mentioned above.
Never use old versions of WinSCP!
