Supported windows systems
vthunda
Gouda, The Netherlands
G'day,
We are currently running WinSCP v5.1.1 Build 2735 on Windows 7.
Will this current version run on Windows Server 2008 R2 or Windows 2012 R2?
Do we need to upgrade the current version to run on the 64bit platform?
Cheers Marcel
Re: Supported windows systems
You should always use the latest version of WinSCP.
We do not support old versions of WinSCP.
Anyway, to answer your question, yes, I believe 5.1.1 works on Windows Server 2008 R2 and Windows 2012 R2, both 32 and 64 bit.
