cust cmd for p7zip to extract 7z file withe spaces in name
TeleTobi
I need your help.
What is the syntax for a custom command via Telnet Shell to extract files with spaces in the file name.
When I send the command: 7za e ""!&""
I get the message command not found.
Any Ideas?
Thanks in advanced
TeleTobi
Re: cust cmd for p7zip to extract 7z file withe spaces in name
Why do you use double double-quotes? Did you try single double-quote? Or even single single-quote.
