How to ignore SessionRemoteException
I have a script in powershell to synchronize to server but i receive this error :
WinSCP.SessionRemoteException: Error listing directory '/System Volume Information'. ---> WinSCP.SessionRemoteException: Permission denied.
Error code: 3
Error message from server: Permission denied
   --- End of inner exception stack trace ---
Is it possible to ignore this type of error and continue to other directory ?
Thanks Regards
Stephane
Stephane Tinseau
Paris
I have successfully ignore this folder with adding the folder name in FileMask options parameter.
$transferOptions.FileMask = "|*.log; *.7z; *.zip; *.ric; *.pag; */System Volume Information/; */`$RECYCLE.BIN/"
But the issue still present with this other error
(f);WinSCP.SessionRemoteException: Terminated by user. ---> WinSCP.SessionRemoteException: Error listing directory '/dir1/dir2/file1'.
Error deleting file '/dir1/dir2/file1'.
I think it's again a permission issue but i can't manage all of them.
So the first question is still available:
How to catch these error without stop the copy.
Regards
Stephane
I'm not sure about a cause of the error. Please attach a full session log file showing the problem (using the latest version of WinSCP).
