Connectivity issue with WinSCP to Unix server.
CthuluAllSpark
We have WinSCP 5.5.3 installed in our operations server and we use it in order to connect to our Unix servers. We have three Unix servers and we are able to connect to two of them but are having difficulty connecting to the third one. I get this error during the sign process.
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended)
From your help page you mentioned this error is related to another issue. I need assistance analyzing resolving this issue.
Re: Connectivity issue with WinSCP to Unix server.
I'd have to see logs from the other servers to know what is different, but:
- You connect with SFTP protocol, what the server rejects.
- So WinSCP falls back to SCP protocol.
- For that it starts a shell.
- But your shell actually starts some kind of interactive menu that WinSCP obviously cannot "talk to".
You need to get rid of the menu to make WinSCP work. Or if you really mean to use SFTP, check why it does not work on the server.
Do you expect this server to behave the same as the other two?
CthuluAllSpark
Please see attached logs.
I have attached examples of successful logins to dvorc001 and dvorc002 and an example of the failed log in to dvorc003.
As I understand you mentioned WinSCP attempts to connect to the server using SFTP and as you see in the attached logs that is the protocol we use. What I don't understand is why WinSCP is falling back to an SCP protocol. It shouldn't do that for us as far as i know.
Thanks.
  • WinSCP.zip (12.48 KB, Private file)
There's absolutely no difference in WinSCP configuration between dvorc001 and dvorc003 logs. So it's something on the server-side.
With dvorc001 and dvorc002, the SFTP works ok.
