Sync fails on File Size - some directories. Time is OK
Joe Codeswell
S.F. Bay Area
Dear Martin,
The Sync fails on File Size for some directories.
Time comparison is OK.
Local is winXP
Remote is CentOS-6 64 bit
In the attached log file:
I sanitized the paths. Please find <JoeNotes> ... </JoeNotes> for my file size failure analysis. Please find also:
<GoodSynch0> ... </GoodSynch0>
<GoodSynch1> ... </GoodSynch1>
<BadSynch0> ... </BadSynch0>
<BadSynch1> ... </BadSynch1>
Thanks for the help.
Love and peace,
Joe
  • sanitizedSynch140601-02jdor@jdor.webfactional.com.log (73.53 KB, Private file)
Description: # i sanitized the paths in this session log
# please find <JoeNotes> ... </JoeNotes> for my file size failure analysis
# find also:
# <GoodSynch0> ... </GoodSynch0>
# <GoodSynch1> ... </GoodSynch1>
Re: Sync fails on File Size - some directories. Time is OK
I'm not sure I understand.
. 2014-06-10 09:20:23.889 Collecting synchronization list for local directory 'C:\leadPathfish\views' and remote directory '/leadPath/fish/views', mode = Local, params = 0x442 (NoConfirmation, *PreviewChanges, BySize)
. 2014-06-10 09:20:24.061 Local file 'C:\leadPathfish\views\appadmin.html' [2012-03-04T22:12:08.000Z] [9108] is modified comparing to remote file '/leadPath/fish/views/appadmin.html' [2012-03-04T22:12:08.000Z] [8876]
What's is wrong about this? The file size differ, so WinSCP considers the file changed as per your (non-default) configuration [comparing files by size, instead of time].
