Incorrect binary transfer using WinSCP
dwade
This file transfer was tested with WinSCP version 5.1.7 and 5.5.3, WinSCP.com, Filezilla version 3.5.3, CoreFTP version 2.2, and PuTTy PSFTP.
All WinSCP application transferred file incorrectly. However the file was transferred in binary but still incorrectly.
CKSUM information for this file should read:
944547907 17021647
When transferred using WinSCP the results are:
1712354705 17021621
or
3436221932 17021621
Re: Incorrect binary transfer using WinSCP
Please attach a full log file showing the problem (using the latest version of WinSCP). Please also attach a sample file.
dwade
Unable to upload the log and orginal file to this site.
I will try later. I could be a problem with my current location.
dwade
Orginal File.
File can be downloaded here. <invalid hyperlink removed by admin>
Now just need to figure out how to get you the log file.
Re: upload limitation..
I have raised the limit to 10 MB. I'm pretty sure that 64 MB log file easily compresses to less than 10 MB. Thanks.
dwade
Additional Information..
I should also mention that file transfer mode is server controlled. This is determined by file extension, example: *.txt = text | *.bin = binary
Again this has been tested with several applications and only failed to work with WinSCP.
Re: Additional Information..
Thanks for the log. I did not find anything unusual there.
Can you get me a copy of the corrupted file and matching WinSCP log file?
How does this work? There's no mechanism for that in SFTP protocol. Anyway, I suppose the server selected binary transfer for the file in question, right?
