Unable to delete remote directory
stephenkugler
Using Version 5.5.3 with Windows XP and Unix Server. Using FTP. Can remove files, but this is the first time I tried to delete a remote directory. Tried delete key, F8, File - Delete (grayed out) while the empty directory is highlighted. Am I doing something wrong or missing something obvious. Help mush appreciated.
Re: Unable to delete remote directory
Deleting directories is the same as deleting files. Maybe you have selected the directory on directory tree instead of file panel?
