Uploading File to SFTP using Key Authentication in SSIS
Ravindra Chate
I want to upload file to SFTP using private key authentication. So I wrote below code in SSIS Script Task. Can you please suggest this much code is enough for the same or am I missing anything? Thanks in advance for your valuable answers.
  Protocol = Protocol.Sftp,
  HostName = sftpHostName, //Destination server to which we need to connect to
  UserName = sftpUserId, //Destination server UserId (or Source server user id?)
  SshHostKeyFingerprint = sftpHosyKeyFingerPrint,
  SshPrivateKeyPath = sftpPrivateKeyPath //Entire physical path that maps to .ppk private key (Eg: C:\PrivateKey\SFTPKey.ppk)
//Start Session
  session.ExecutablePath = executablePath;
  session.Open(sessionOptions);
  // Upload files
  transferOptions.TransferMode = TransferMode.Binary;
  TransferOperationResult transferResult;
  transferResult = session.PutFiles(fileToUpload, sftpDestinationServerPath, false, transferOptions);
  // Throw on any error
  transferResult.Check();
Also put query on the WinSCP site forum and put the below code [2] in there to check if this code will be good enough for authentication and file transfer using private-public key? Or else additional coding is required for key authentication.
asher629
Mobile, AL
using private key for an SFTP connection from SSIS package
Martin, which of the following parameters named in the thread I am responding to, for an SFTP connection with a private key are mandatory: Host name, User name, Ssh Host Key Fingerprint, Ssh Private Key Path? Someone I need to send files to, and receive files from, gave me the host name and private key only. No fingerprint, no user name. Thank you
asher629
Mobile, AL
Thank you, Martin. Will the attached image give you any clue as to what I did wrong in establishing a new connection? I will send an email to introduce myself, will post all the questions here. Thank you
  • time_out.JPG (88.79 KB, Private file)
Re: using private key for an SFTP connection from SSIS package
Can you connect to that hostname using any SSH/SFTP client at all? Can you ping the host?
