PowerShell example for downloading latest file
freff
Uk
I am new to scripting and opted for the PowerShell example purely because I have PowerShell on my laptop.
In the example that is supplied on the website I am having issue with the code and suspect that it is related to me not the example.
Here is the example that you have supplied:
https://winscp.net/eng/docs/script_download_most_recent_file#powershell
My first thought it was going to be straight forward, however had an issue registering winscpnet.dll then an issue with the script DirectoryInfo was not a cmd, I guess that this line needed a $ before the command.
After inserting a $, the script now moves onto the next issue.
Can't get attributes of file '/usr/xxx/xxx.cvs'
Can some one please point me in the right direction I have ensured that I have two files in the folder and while they have the same date stamp they do have different time stamps.
Any help would be great
Regards
Steve
Re: Powershell example for downloading latest file
First, thanks for pointing out the problem with missing $.
Regarding the error: What is /usr/xxx/xxx.cvs? Is it a path you set $remotePath to? The purpose of the script is to find the latest file in a directory. So the $remotePath should be set to a path to the directory, not a specific path.
Posting a complete error message, or even better a log file, would help.
freff
Uk
Hi @Martin,
When I run the PowerShell script it does not create a log file
After looking at the error I can see that on the remote path I am missing the / at the end I have added the / for the path and it appears to be working now.
Many thanks for your help
Regards
Steve
justadakaje
Dallas, TX, USA
Where clause to filter out directories not working?
Hi @martin
For me, the PowerShell Where-Object clause to filter out directories from the Files collection does not seem to be working, as intended. I'm essentially using your whole script example from https://winscp.net/eng/docs/script_download_most_recent_file. I can manually step through the script, line by line and when I execute the following, a single file is never selected...
# Select the most recent file
$latest =
    $directoryInfo.Files |
    Where-Object { -Not $_.IsDirectory } |
    Sort-Object LastWriteTime -Descending |
    Select-Object -First 1
Could this just be a problem with the FTP Server to which I'm connecting? I know there are files present because I can manually open WinSCP client and see them. I'm just trying to automate the process to download the latest file.
justadakaje
Dallas, TX, USA
Found a solution: use $session.EnumerateRemoteFiles
In my case, the FTP Site consists of subdirectories of a timestamp and the files I need to download are inside those. So, rather than doing a
$directoryInfo = $session.ListDirectory($remotePath)
which now I understand would be useful if all the files I'm looking for are in a single remote directory, I'm doing a
where I'm specifying the remote path, a wildcard, and the EnumerationOptions of AllDirectories so I can be sure to always find the latest file. If there's a cleaner way to do this, I'm all ears. But, in my case, since the remote directory contains a collection of subdirectories, the ListDirectory method wasn't returning the collection of files. Hope this helps someone else! Cheers!
Re: Found a solution: use $session.EnumerateRemoteFiles
@justadakaje: If you need to search for the latest file recursively, then indeed the Session.EnumerateRemoteFiles is the right way.
