Problem with WebDAV support
Draghmar
Hi
I just tried alpha build with experimental WebDAV support but I can't get it to work with IPB software. It's quite possible that I made some error during configuration...
IPB has support for remote editing themes by using webdav. It is done by connecting to dav.php file. I tried to enter only host but it didn't work. I tried then adding /dav.php to host but it still didn't work. I mean...it looked like it has connected but there was no files in panel.
Did someone tried IPB and their webdav support?
Did you enable external editing as per instructions on:
It works for me (even on demo account).
I'm sending an email with the latest build of WinSCP with improved WebDAV support.
Draghmar
Yes, it is enabled. Thx for the newer build by the way. Not sure what *was* wrong but after few attempts on this new build I did manage to connect properly.
I think it has something to do with Host name field. Using full address makes proper connection but there is one thing that makes saved session a little bit confusing. When I put http:// and change focus to another field both http:// and /dav.php parts will be stripped. But entering address without those two parts results with wrong connection. Normally I enter address without protocol (I'm using WinSCP mostly for FTP connections) and it worked without any problem this way so far.
The Host name box is for hostname only.
But as people tend to paste there a complete session URL, WinSCP is smart enough to parse the URL into protocol (http:// selects WebDAV), username and password (if any), the actual hostname and an initial path (/dav.php that goes to Advanced > Environment > Directories > Remote directory).
You are right that without protocol and path, it won't work, but there are separate boxes for these.
Alternatively you can select New Site and use Manage > Paste Session URL command.
Draghmar
Oh...that would really explain a lot. :D I just didn't know where I have to put /dav.php part. I didn't know that I can put file in a field called Remote directory. ;)
Thx for your help. :)
While the /dav.php is actually a file, from WebDAV protocol perspective (as WinSCP sees it) it is a folder.
E.g. when you go to a subfolder, you end in /dav.php/1__IPBoard/blog_cblocks.
