I get stuck installing Kaazing WebSocket Gateway
Niek
I try to install Kaazing WebSocket Gateway on a DNS to which I have root access and with which I communicate through WinSCP. I use the step-by-step guide from Kaazing. All goes well until I arrive at step 10 where it says:
On Linux/Mac, run the following command from the terminal:
./gateway.start
When I do so I get the output as described in the guide, including the message that the server succesfully started, but the process doesn't seem to come to an end. After a while I get the message that the host "..is not communicating any more. Waiting..." I'm using the Dutch version, so this is a translation of the Dutch message that I get. At that point I can choose between clicking the Abort-button, which means thet the connection will be aborted, or waiting until the message disappears. After 4 hours of waiting the message is still there, so I better click the Abort-button. Which means that the output from the terminal disappears and I have to reconnect to my DNS. So I'm still not sure if the websocket is functioning properly. Does it? Or is there something else that I should do?
Thanks for helping me out.
Niek
Re: I get stuck installing Kaazing WebSocket Gateway
If ./gateway.start is synchronous script, it hangs WinSCP. That's expected. I suppose the gateway is running as long as the script is running. If you really need to run the script from WinSCP (I wouldn't expect that) you can create a wrapper script that calls ./gateway.start & to run the gateway in the background, not to block WinSCP.
pmoskovi
Based on your description, it sounds like this is a winscp issue. If you feel you need help with Kaazing, feel free to reach out for help through the Kaazing forums on <invalid hyperlink removed by admin>
Regards,
Peter Moskovits
Head of Real-Time Solutions
KAAZING
