Speed up bulk deletes
ks
Moscow
Hello. When I happen to select many files and delete them it takes Win SCP too long to delete them all one by one. At the same time, if I delete them in PuTTY with rm *.* or in mc using multiple selection the deletion is instantaneous. Can you implement multiple deletion using bulk operations, for example by passing rm up to 64 files at once? Response codes do not matter here.
Re: Speed up bulk deletes
I suppose you want this for SCP protocol, correct?
