Progress Bar shows momentarily using .NET in Powershell 4.0
mwetmore
Philadelphia, Pennsylvania US
Running in Powershell ISE or in CMD.EXE a progress bar flashes up for a moment. How to prevent this? The script will be run by a scheduler. Not using sync, just $session.PutFiles() and $session.GetFiles() for transfers, all piped to Out-Null.
BTW at https://winscp.net/eng/docs/library_example_listing_files_matching_wildcard this:
foreach ($fileInfo in $directory.Files)
should be:
foreach ($fileInfo in $Files)
mwetmore
Progress bar
When running the ps1 in 4.0 ISE by clicking :arrow: to execute the console shows the full path to the script, then just before the script exits a GUI blue progress bar flashes up on the top of the console. It is a very quick flash, I have to be staring at the right place to see that the short disturbance.
Similarly when I run the script by invoking powershell in a cmd window, there is a quick flash of 'ooo...' that moves across the top of the window.
These are all the assembly methods used, in the order that they occur. The script runs in < 30 seconds
 # SFTP does not have an append verb so it has to be get->append->put
        $rem = "{0}{1}" -f $carrdir, $rcdf
        if ($send -eq "R" -and $session.FileExists($rem)) {
            if ($session.GetFiles($rem, $rcdtemp).IsSuccess) {
                $session.RemoveFiles($rem) | Out-Null
                Get-Content ($rcdtemp) |
                    Add-Content ("{0}\{1}" -f $temploc, $rcdf)
            } else {
                CleanUp-Exit(2)
        # This creates a directory in $carrdir named like $temploc
        $session.PutFiles($temploc, $carrdir).Check() | Out-Null
        # Get list of files uploaded
        $files = $session.ListDirectory($carrloc).Files | Where { -not $_.IsDirectory }
            # Move the files up into $carrdir
            ForEach ($fileinfo in $files) {
                $session.MoveFile($carrloc + "/" + $fileinfo.Name, $carrdir)
   if ($session.Opened) {
        $session.RemoveFiles($carrloc) | Out-Null
        $session.Dispose()
Re: Progress bar
WinSCP .NET assembly does not present any progress bar (it has no GUI at all). So it has to be your run-time environment that shows the progress bar.
