Can I use WinSCP in VB application
m87ie
I am involved in transferring very heavy files sometimes 1 GB in size to remote FTP server. I have tried to use FTP through WinInet control. But it is extremely slow. Could anybody suggest me a quicker way to tranfer the files especially using SSH.
Although third party controls are available on the web which are fast but they are very expensive and I cannot afford to use them. As I am not into commercial buisness.
I would deeply appreciate any help in this regard.
Maz
Re: Can I use WinSCP in VB application
You cannot use WinSCP as an ActiveX control or similar. I do not know any such tool :-(
ManChicken
Chicago, IL
Maz
Try OpenSSH. It'll require more than simple VB to use it, but it works. They have it for windows.
Reply with quote E-mail
